It is currently Mon May 25, 2026 11:40 am
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sun Jan 17, 2010 1:10 pm
That would be good if the spring will fit in the shock tower.
PostPosted: Sun Jan 17, 2010 2:42 pm
yea im using an offroad spring off of an older toyota. im also thinking about doing a coilover on the rear and a 4link. what do you guys think?
PostPosted: Sun Jan 17, 2010 2:50 pm
Decent front coilovers are just as important as the rear ones when you start trying to put horsepower to the ground...
PostPosted: Sun Jan 17, 2010 3:51 pm
ya your right. ive heard a lot of different views of taking the torsion bars out and what not.
PostPosted: Sun Feb 14, 2010 11:44 pm
Just finished with mine. '74 with a 350/th350 and used Aldan coilovers. 11.75 extended length, used channel and moved the upper mount outboard 3/4" from the stock mount. Ended up trying several different springs and stayed with a set of 500# springs, cut 3/8" off the lower snubbers for more travel and it sits good and has way better ride than before.. Love it. Hope this helps.. :ebiggrin
PS - the reason I went with the heavier springs was the 350# springs were nearly at coil bind when I bounced the front end in the shop. Not enough resistance and I didn't want to break a spring on the street. :D :D
