It is currently Tue May 26, 2026 4:24 am
 Post subject: spindle
PostPosted: Wed Jul 29, 2009 10:47 pm
Hi can anyone help me, i've found a guy that makes a 5 stud conversion hub to suit the RODEO/PUP which came out from '80 onwards as far as i know. I've got a '75 luv 2wd and was wondering if the front wheel bearing size would be the same therefore letting me use the hub to change from 6 to 5 stud. Any help would be gr8 thanks.
 Post subject: Re: spindle
PostPosted: Thu Jul 30, 2009 6:59 am
There are other factors involved to hub conversions.
Bearing size
length of hub (or spindle)
rotor/drum spacing (offset)
caliper/shoe size
mounting or face offset
od/id
There is a sticky on using Toyota p/u rotors
