It is currently Mon May 25, 2026 6:58 am
 Post subject: FRONT COIL OVERS AGAIN
PostPosted: Fri Jul 11, 2003 6:41 am
I know this subject has been talked many times.
For anyone that has done this, what was done to the torsion bar, just cut it off where it comes out of the lower control arm? I am going to do this soon, it looks like a fairly simple mod.
PostPosted: Mon Jul 14, 2003 5:11 am
that is all I did. I cut them off and drilled a hole in them for a pin.
beware....they are hardened or sumpin...they will chew up a sawzall blade with a quickness.
03Cobra
PostPosted: Mon Jul 14, 2003 11:14 pm
I just unbolted the rear adjuster,took them off and pulled torsion bar out.Picking up correct spring for coil over tommorrow.hopefully try to install this weekend
PostPosted: Tue Aug 05, 2003 12:12 pm
what coil over springs are used? Does someone make some for the luv, or are you using some from another truck? I am interested in doing this mod, any help would be great. Thanks
Dan
No LUV anymore, but still in the GM truck family. Running a lifted 2002 Silverado Z-71!
