It is currently Mon May 25, 2026 10:01 am
 Post subject: Leaf Springs
PostPosted: Wed Jun 11, 2008 7:13 am
My 4x4 sags a bit in the bag, has any body used those helper springs before?
 Post subject: Re: Leaf Springs
PostPosted: Wed Jun 11, 2008 7:38 am
There are places that will re-arch your springs. They heat and re-temper the springs. And all I have done they have put new bushings and put new center bolts. They can add a spring if you want. All I have used in the past knew their stuff and I have had a butt load done. It was in Houston, but you shouldn't have any trouble finding one in SA.
PostPosted: Wed Jun 11, 2008 10:23 pm
I added them on my truck. They did raise the truck up. They are good if you want to haul a load too. However the extra leaf spring that you bolt on does stil down some.
Rearch the srpings would be better.
