It is currently Mon May 25, 2026 10:00 am
 Post subject: TBars
PostPosted: Sat Apr 05, 2008 9:07 am
Ok boys and girls it's time. I'm gonna do it. if I mess up I will have a Luv frame.body and everything to ditch. I need to know exactly how to get my tbars off. Do I also need to replace the bar with a bolt were they go through the lower a arms.
 Post subject: Re: TBars
PostPosted: Sun Apr 06, 2008 7:39 pm
TBars out and xmember gone. Now comes the new xmember and motor mounts. Will try and find some coil overs even ig I have to go new. Watching some on ebay mytmouz found for me.
My ole back is killing me from bending and cutting. :esurprised
PostPosted: Tue Apr 08, 2008 6:06 am
So can I take the bar off that bolts in the front from the were the lower control arms are attaced and goes sise to sise. Is it just for strenght in the front to hole it together, Sits right under my oil pan
PostPosted: Tue Apr 08, 2008 9:28 am
That piece needs to stay.
PostPosted: Thu Apr 10, 2008 8:32 pm
Hmmmm, I see QA1 makes a stud mount conversion for coil overs.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... =p3907.m32
Wonder if these can be shortened by lowering the spring adjuster down or will it make the shock bottom out.
