It is currently Mon May 25, 2026 10:36 pm
PostPosted: Sat Jun 02, 2007 9:35 pm
Does anyone know, how to paint the white letters on the dash board ? I mean to make them look like new ( lights , A/C controls, etc. ); I painted the whole thing black, but painted the letters as well...
thanks for your help !! :?
 Post subject: .
PostPosted: Sat Jun 02, 2007 9:44 pm
Applying silver leaf may actualy be easier than painting.
FIAA: Color Guard
PostPosted: Sat Jun 02, 2007 10:40 pm
Try a very fine modeling paint brush. Get one from a hobby store.
PostPosted: Sun Jun 03, 2007 9:28 am
I've had the best results with a small foam brush, and model paint. Wet the brush on the flat side and lay that on the letters, it may take a few tries to get it right, but it puts on a pretty even coat once you get the hang of it.
If they are recessed, you can also use the sponge brush to fill the letters and then wipe off the excess. Obviously, this works best if the part can be laid horizontally so the paint won't run out.
This idea works well on stuff like your valve cover too. Fill the brush up heavy to do the indented parts, wipe off the excess, let it all dry, and then use the brush with a light amount of paint to do the raised portions in a contrasting color.
Good luck 8)
PostPosted: Mon Jun 04, 2007 10:11 pm
Thanks guys, the help was more than expected !!!
I'll try nukeday's method first ( I have some modeling paint )...
:P
