It is currently Tue Jun 30, 2026 3:59 am
PostPosted: Thu Mar 23, 2006 10:09 pm
I bought the super comp headers, motor mounts, and trans mount for the v-8 swap but I need to know if you can leave the stock torque arms in place or do you have to swap to coil overs in the front to make the headers clear? Thanks
PostPosted: Fri Mar 24, 2006 12:47 am
If you're refering to the torsion bars, the headers are designed to fit the stock setup. Coil overs aren't required. They're a pain to fit in place while you lower the engine in to the frame but in the long run, It's well worth the hassle.
Read the installation directions fully to see exactly what needs to be done. If you run into any problems, just shout and im sure many of us can give you help.
