It is currently Sun Jun 28, 2026 12:27 pm
 Post subject: tranny question
PostPosted: Tue May 30, 2006 1:25 pm
will a 5 speed g200 fit a g180? i like to go fast but i don't like to tach out my engine to do it.
PostPosted: Tue May 30, 2006 9:23 pm
i think that it should work!!
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Tue May 30, 2006 10:05 pm
Swap Specialist Mod
yeah itll work. the g200 is basically a bigger bore g180.
PostPosted: Wed May 31, 2006 11:34 am
awsome! thanks for the info guys now i just have to find a g200 tranny :P
PostPosted: Wed May 31, 2006 3:03 pm
Check Isuzu pickups, 83-93 or so. The trans behind a G200 (1.9L) or a 4ZD1 (2.3L) should be the same. If you find one with a cable clutch it should be pretty close to drop in, though I have honestly not measured the length on a pickup tranny. The 88 Impulse car 5 Spd I've got is the same length as my 2WD 76 LUV tranny, but it is set up for a hydro clutch so it would be more trouble to make work in an 80 LUV. I believe the 2WD pickup trans will be the same, but already set for the cable clutch. If you see a pickup with a hydro clutch, it will be a bit different trans and likely behind a 2.6L 4ZE1. Not that it wouldn't work, but it would tend to be more different and require more work to bolt it up. Diesels have a different bolt pattern, so the 5spds from them will not work on a G180.
If you are looking for a 4x4 trans then look at 4x pickups and Troopers. The trans is longer though, so driveshaft mods and mount fabrication will be required.
