It is currently Mon May 25, 2026 3:16 pm
 Post subject: Rear End Lockers
PostPosted: Mon Feb 13, 2006 7:13 pm
Does anybody know of any type of lockers or posi units are that are availible for the stock luv rear end. If not, is it possible to do it by welding the gears in it thats kind of a last resort idea cuz I've heard bad things about doing that. Thanks alot!!!
PostPosted: Tue Feb 14, 2006 12:17 am
there was an isuzu rearend that had posi from the factory, but it was a little bit different than the stocker. as for a locker, that will do the same damage welding the gears will. if you arent gonna drive it on the street alot, you can weld it and be okay.
PostPosted: Tue Feb 14, 2006 10:14 am
It won't be driven whole lot sort of a weekend cruiser but it would be nice if it would hook up a little when someone pulls up next to me and thinks they are fast. On that note any good ideas or pictures for ladder or tractionn bars availible??
PostPosted: Wed Feb 15, 2006 12:37 am
check out the picture gallery. look in the projects section.
PostPosted: Sun Feb 19, 2006 5:53 pm
If i were you (and i am not) i would replace the rear with a 10 bolt,or 9in,If u are lookin to race.That rear wont hold up with a locker or welding.
PostPosted: Sun Feb 19, 2006 10:28 pm
sorry i accidently posted two times :idea:
