It is currently Tue Jun 30, 2026 10:53 am
PostPosted: Sun Feb 09, 2003 7:52 pm
Since no matter what vehicle you get one out of, it seems like you're going to have to narrow it anyway, what vehicle seems to be the best source for a 9 inch rear end? Do any come stock with disc brakes?
RATNLUV, I believe you told me that the width to get it narrowed is 41 inches. Is that pretty close to stock?
Thanks
PostPosted: Mon Feb 10, 2003 12:42 am
I pulled mine out of a Lincoln Town car that had rear disc brakes. Only problem was that the calipers hit my rims and I ended up buying a whole disc brake kit from Currie anyway. So, the stock discs were kinda a waste of money for me.
So if you get one from a Lincoln, you may have trouble running a wide 15" rim in back.
PostPosted: Mon Feb 10, 2003 9:30 am
What year did you get your's from? Or does it matter?
I had a Firebird once (I FU*KN miss that car) it had rear discs and that thing stopped on a freakin dime. Anyway I had a blowout and threw on a makeshift spare from a junkyard, and sure enough, it rubbed the hell out of it. Those were some deep ass rims!
PostPosted: Mon Feb 10, 2003 3:24 pm
hey i have a lead on a nine inch out of a 1969 mach 1 mustang how close is it? i called some one here in town and they said almost 6 hundred bucks once you throw in all the axles and everything. can the origional axles be shortened or would it be cheaper to just get new ones. HELP!!
PostPosted: Mon Feb 10, 2003 5:16 pm
i was told the rear end out of a mercury versalies , i think i spelled that right, is real close to the stock luv rear. it comes with disk brakes i just found that one out this weekend. the guy said he thinks his was 55" wide from wheel mount to wheel mount.i guess its a hard car to find though. hey drummer don`t forget rat n luv is tubbed his rear will be narrower unless your planning to tub.later terry :twisted:
PostPosted: Mon Feb 10, 2003 6:53 pm
From what i've figured out, the bigger the vehicle, the better the 3rd member. The larger cars had 3rd members that were 31 splined axles. The smaller cars(mavericks, granadas, Mustangs with 6 cyl engines) primarily ran with 28 spline axles. Aim for the 31 spline set up. You'll have more room to mod the engine before you have to worry about the axle going bad.
PostPosted: Mon Feb 10, 2003 7:37 pm
72 lincoln. Mine has drums, but i have discs up front. 31 spline. a guy in marysvill did all the work for $150. narrowed, cut and resplined the axles.
PostPosted: Mon Feb 10, 2003 9:17 pm
Mine is 39" outside wheel flange to flange. Ask the guy running the junk yard to make you a good deal on whatever he thinks he will never sell. I got mine when I junked a 70 ford van.
The best thing to do is buy your wheels and tires and put them under the truck to get the measurement for you rearend.
stripped and just a memory!
PostPosted: Mon Feb 10, 2003 9:45 pm
I will be getting my 3rd member and housing back from the builder this week. When i get it home i'll measure the width from bearing flange to bearing flange. And from axle flange to axle flange. I'll post the measurements. This setup im running P265/60R-14 tires. 8" wide rims with 0 rim offset. The truck has a stock look to it if thats what your going with.
PostPosted: Tue Feb 11, 2003 12:06 am
anyone ever see the ads for the FAB 9. its a aftermarket fabricated housing that takes 9" center. pretty bad lookin unit. they cut to fit. $$$$$
PostPosted: Fri Feb 28, 2003 10:23 pm
I do believe a 68-72 Bronco rearend is as close as you will get to the stock Luv width. It's 51" wide, backing plate to backing plate. About 3" wider thn the Luv.
When everthing goes wrong....
What's right is what's left.
 Post subject: 9" or 8" ford
PostPosted: Sat Mar 01, 2003 10:28 am
OK I'am new here but i have checked this site out while building my LUV ,i found a web site that mite help on ford rearends.
http://hiqties.hypermart.net/9inch.html
PostPosted: Sat Mar 01, 2003 11:10 am
Welcome, another washington owner. give some details on your truck.....
later
PostPosted: Sat Mar 01, 2003 1:04 pm
Excellent find Chris..Thanks! I've copied it to my computer for future reference. Welcome to the site.
I'd like to get some feedback on what this axle guy told me: He said that i had Chrysler axle bearing housings in my Ford 9" differential. I've never heard of such a thing. When i replaced the bearings for my axle shafts, I got stock replacements and they fit correctly. The backing plates fit correctly to the bearing housings. Even the axle seals fit correctly to the housings. I think he's feeding me a line of crap. He went on about how he had to fab some pucks to align the axle(stall tactic?). Can anyone shed some light on this or does this guy think im a mushroom?
PostPosted: Sun Mar 02, 2003 2:12 am
Well lets see i got a 76 luv short box i put in a 283 .060 with a turbo 350 tranny and after that first ride going to put in a ford rearend the gears raito was murder on the motor as soon as i figure out how to post pics i'll do that
PostPosted: Sun Mar 02, 2003 2:53 am
I hear ya! I was amazed the first time i drove my truck with a TH 350 and the stock rear end. 0 to 50 was very, very cool but it's hell on the Hwy with traffic ready to run over you and the engine temp showing a nuclear meltdown reading. Low gear was almost non-exsistent and dont even dare to drop the trans manually into 2nd while you're still rolling. From a dead stop i could drive casually and at about 80' it would shift into 3rd already. It was fun but not practical. I'm running with 2.75 gears and it works great for me. 2500 RPM @ 70 MPH. Initially i thought that this ratio would be too tall but it has worked out very much to my satisfaction. There's a link to a couple of gear ratio calculators in the information section of this site. You might want to use them to get an idea of what ratio you want or to see what you will get with the ratio you've already decided on.
PostPosted: Sun Mar 02, 2003 8:51 am
283?!? nice. someone else here has been askin a lot about a 283. Husker- that u? Im excited to see it. get it ready for summer cause i feel a LUV meet in the air. Either in seattle, spokane, or maybe Cd'A.
PostPosted: Sun Mar 02, 2003 9:20 am
Hey Chris welcome to the site I will definitley have to get together with you and get some pointers! I live just around the corner from you I'm on Ft. Lewis :lol: I used to live in Spanaway when I first got here was living right on Spanaway Loop, Anyway I just picked up a 283 for my truck and am going to do the conversion on it as soon as I get back from playing in the desert. :lol: But anyway It's good to see someone else who is close and can give me some insight on things to come. Well Talk to you later.
PostPosted: Sun Mar 02, 2003 10:32 am
Ok husker sounds good ,looking forward to making to a meet up here when ever it will be,do they have a like a swap meet for parts at the meet? i looked at the caulator for gears and 3.25 to 3.40 i'll be just perfect , i did the racing at spanaway speed thing and it has gotten old so now on to the luv truck.thanks for the welcome aboard and all the helpful info at this site
Users browsing this forum: Baidu [Spider] and 45 guests
