It is currently Mon Jun 29, 2026 1:39 am
PostPosted: Tue Jul 02, 2002 7:16 pm
Hi, I have a 73 luv and going to put a 80 stock luv engine in(the 73), anyone know what kind of problems I could run into. Thanks TimO
PostPosted: Wed Jul 03, 2002 8:11 pm
Does your '73 motor have the overhead cam like the '80 model? I'm not sure what year they switched over. I think it was '76.
PostPosted: Wed Jul 03, 2002 8:37 pm
Hi Ben,
yes the early model has the overhead cam, they changed the LUV in 76,
yahI see some differences when I go to switch the 80 into the 73, hoping someone has done this and can let me know of any major problems they ran into.....( im guessing that it will bolt to the bell housing).Thanks Tim
PostPosted: Sat Jul 06, 2002 3:11 am
I just got done putting a 85 isuzu G180 motor into my 74 chevy luv. The major problems were:
1. converting from a hydraulic clutch to a cable
2. making some adapter plates to link up the orginal motor mounts
3. hooking up the radiator hoses since they were on opposite sides of the engine.
I am using it as my daily driver now and it sure is better that the old engine. Let me know if you run into problems and maybe I can help with pictures. I am a computer novice but I might be able to send some pictures if you need.
Good Luck, John B.
PostPosted: Sat Jul 06, 2002 7:19 pm
Thanks for the reply, im hoping to keep the hydualic clutch, but will see, did you use the manual clutch from the later model luv????76 and on??
Tim
PostPosted: Sun Jul 07, 2002 2:29 pm
Tim,
I used the engine and tranny from the 85 Isuzu (76 and later Luv). My orginal tranny was noisy and I don't think it would match up to the later engine. On converting to a cable I removed the hydraulic stuff and got a brake/clutch pedal bracket assembly from a 76 Luv and it bolted right into my 74. I had to drill a hole in the firewall where the cable comes through and make a bracket to hold the cable housing at the firewall. I also made a patch to cover the hole were the old hydraulic cylinder was.
I hope this helps, John
