It is currently Tue Jun 30, 2026 1:03 am
 Post subject: Small Block Motor Mounts
PostPosted: Sun Jan 29, 2006 11:01 pm
Hey Guys !! I was just wondering if anyone could tell me what motor mounts on the engine side are needed to match the hooker frame mounts for a small block in the luv. thanks for any info.!
PostPosted: Mon Jan 30, 2006 2:13 am
Swap Specialist Mod
you need block mounts from a 71-82 camaro, or something equivilent to that.
PostPosted: Mon Jan 30, 2006 11:46 am
Cool Thanks a;ot!
PostPosted: Fri Feb 03, 2006 1:52 am
Japanese Redneck
I'd recommend the following:
1. Moroso solid steel mount (if vibration is not a concern)
2. Energy Suspension Poly Eurethane mount if vibration is a concern
3. factory GM (Camaro) mount and drill a 1/2" hole in the center and install an bolt with a washer under the head and a washer and nut on the other side to prevent separation (achieves the same goal as the energy suspension mount) this is an old school hot rod trick.
4. Stock GM (camaro) mount and chain or strap the drivers side of the motor down with Home Depot parts. achieves the same goal as the energy suspension setup. also an old school hot rod modification.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
