It is currently Mon Jun 29, 2026 3:57 am
 Post subject: gear ratio?
PostPosted: Tue May 14, 2002 4:23 am
Need to swap rear end out and was wondering what gear ratio works best with the 350/350 swap?
 Post subject: REAR END GEARS
PostPosted: Tue May 14, 2002 6:01 am
:n00b: HI There bob i put 3.73 gears in to my stock luv truck, they seem to work great ,,,,matt
PostPosted: Tue May 14, 2002 12:39 pm
As with all cars, it depends upon the RPM range of the engine, the height of your tires, and what you plan to use the truck for. 3.73's like MATT suggested is a great all-around gear ratio.
