It is currently Mon May 25, 2026 2:23 pm
 Post subject: ultrabell ??
PostPosted: Tue Dec 27, 2005 3:25 pm
any of you v8 guys have any trouble with bellhousing breakin and what would cause it. maybe pinion angle or something. all trans and motor mounts are solid just wondering if any body else has had this problem. any replys would be greatly apreciated
PostPosted: Tue Dec 27, 2005 6:03 pm
Japanese Redneck
only time I've ever busted one was when i sheared what I think was a defective solid cross (spicer) U joint at 120+mph and the shaft hit the ground which shocked the trans case and shattered the bellhousing. this is the remains of a 6 week old 4L60 in my 93 Z28 on the jug.
The trans almost came out on the road. the only thing holding it in there was the rear mount and the case in that area was cracked too.
stock bellhousing is fine on med-high perf but a full race trans with a brake and 6000 stall would probably be safer with a JW installed
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Wed Dec 28, 2005 11:00 am
Looks like that was a fun ride :lol:
PostPosted: Wed Dec 28, 2005 10:35 pm
Japanese Redneck
yeah... that happened right after i just got done doin a 130 mph blast. I just lifted and was decel'ing to 120-125 when the u joint let go. this was on the I-5 at 6:30am. the shaft hitting the ground sent a shower of sparks everywhere which parted the cars behind me like the red sea.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Sun Jan 01, 2006 11:44 am
LUVTruck.com's Cornholio
damn you hammered that tranny.
PostPosted: Sun Jan 01, 2006 4:09 pm
i have never seen anything of that nature before.., but damn that things is f*cked lol
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Sun Jan 01, 2006 5:10 pm
damn!! that tarnny is done!!
theres a later model chevy truck at the local junkyard thats wrecked and the tranny is broke like that in it. crazy stuff!!
PostPosted: Mon Jan 02, 2006 1:18 am
That is about what my stock luv 4spd looked like after I hit a bridge head on.
My dad bought a Chev 4x4 pickup that had similar damage to a TH400. It was an old farm crummy, and if you ever worked on a farm as a teenager you would know exactly how that might have happened. ;)
PostPosted: Tue Jan 03, 2006 6:13 pm
Japanese Redneck
oh thats nothing. u should see what happens when an intermediate sprag lets go while ur buzzing 8000 RPM.....been there done that. I got lucky the LUV floorboards kept parts from coming into the cab.
I've also seen a shaft let got and hit the ground, bust the trans like that AND thrust the crankshaft forward in the motor.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Jan 03, 2006 11:16 pm
Damn!!!!
PostPosted: Fri Jan 06, 2006 11:18 am
Chassis flex in a Drag Racer will break at the bell housing area. Been there done that several times before realizing the problem.
Users browsing this forum: Bing [Bot] and 19 guests
