It is currently Mon May 25, 2026 1:18 pm
PostPosted: Wed Dec 07, 2005 9:03 pm
What is the exact difference between a 327 and a 350? what can be done with a 327? can it be made into a stroker? I just got a 327 for $300 and was wondering what can be done? My buddy is offering me his high rise tunnel intake. what will it do? another guy said he can turbo it for me and get good hp.
Thanks
PostPosted: Wed Dec 07, 2005 9:14 pm
i am far from an expert.. but as far as i know.. the 327 is a SBC, and shares the 350's bore.. but has a shorter stroke.. hence a lil easier to rev higher and less low end torque than the 350.
i beleive that there are some differences in cams and whatnot as well
other with give you much more info.. as well as probably correct mine :lol:
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Thu Dec 08, 2005 9:25 pm
Swap Specialist Mod
reffer to this.
http://forums.luvtruck.com/viewtopic.php?t=8389
PostPosted: Fri Dec 23, 2005 3:02 pm
Japanese Redneck
its all about what you want to do with the motor. you can do the same stuff to a 327 as to a 350 its all about moving air in and moving air out. carb, intake, headers, cam, heads, etc. etc. . stepping up any one of these (preferrably all of them) will free up HP in your 327.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
