It is currently Mon May 25, 2026 1:02 pm
 Post subject: Please help...
PostPosted: Mon Aug 29, 2005 1:31 am
Ok I am almost positive that this motor I have is a 350 but i want to be sure and I cant find anywhere online that recognises the #'s I have.
I got these #'s off the block.
on the end it says H36
On the side it says CFD 207
And on the little plate on the top of the block it says V0522FSA
CE0174289
Please help!
Also I got some #'s off the crank cause I was told it was a steel crank and I want to make sure the #'s I got are
CFD 130 and 3932442
Also I got some 3's off the cam I think its just a stock cam but these are the #'s
GM23 and 0G50
Please help lol. Thanks in advance.
PostPosted: Mon Aug 29, 2005 1:46 am
check on the block where the yeller square is.
PostPosted: Mon Aug 29, 2005 1:49 am
Thats where it says
V0522FSA
CE0174289
PostPosted: Mon Aug 29, 2005 12:49 pm
If you take all the numbers you can find to a Kragen or any autoparts store they should be able to cross the casting numbers tell you what you have. Some how-to books have reference lists for the casting numbers. I have a 350 an 89 I think and has 5.7 on the bellhousing.
PostPosted: Mon Aug 29, 2005 1:17 pm
http://www.nastyz28.com/sbchevy/sblock.html#general try this site. I couldnt find any info on those numbers, maybe you have something mixed up??? I dont know but I hope this helps!
PostPosted: Mon Aug 29, 2005 1:19 pm
The V number, all it tells is that the motor came from the Flint plant, born on May 22. The FSA part is where I loose it :evil: Good luck!!!!!
PostPosted: Mon Aug 29, 2005 2:54 pm
http://www.Mortec.com has the crank number you list. Of course it just says it is a cast part 3.48" stroke, from a 267, 305, or 350.
It almost looks like the block casting number is missing from the ones you list to me. The V number is the assembly date code, and the CE one looks like a serial number. The fact that is starts in CE would indicate it is a Crate Engine, or a replacement. Anything that did not come in a vehicle from the factory should have a CE stamped into it. So, it could have been bought in a box, replaced under warranty, or replaced at some later date.
To me, odds look good that it is a 350, but this isn't my area of expertise. I just thought I'd take a crack at it, since knowing a little about how to read a GM V8 could come in real handy.
PostPosted: Mon Aug 29, 2005 3:40 pm
your crank:
3932442
cast nodular iron
3.480 stroke
1968-1985
PostPosted: Mon Aug 29, 2005 3:43 pm
i have a book with all the casting numbers for cranks and blocks and your crank was in there but your block wasnt...
PostPosted: Mon Aug 29, 2005 5:25 pm
I think I got the wrong numbers off of it apperently you have to look on the passenger side I think I got those from the drivers side Thank you for the crank info! That dude told me it was a steel crank bastard but oh well it was free. I was talking to a chevy engine builder and he said its most likely a 350 cause its a 4 bolt main. Apperently they didnt make 4 bolt 305's. Thanks again guys I will get the other #'s and post them when I do!
PostPosted: Mon Aug 29, 2005 5:36 pm
yah no problem i looked in my book again and saw that 4 bolt main was only under 350 engines so most likely it is a 350
PostPosted: Mon Aug 29, 2005 6:42 pm
there were no 4 bolt 305's so hopefully you have a 350 and not an older motor
PostPosted: Mon Aug 29, 2005 6:54 pm
4 bolt, 302, 327, 350 and 400 sbc not every one, but I think all the 302s were. Nothing else had them from the factory in the small block..
I don't know about the new stuff. LS1 or such.
Richard
PostPosted: Mon Aug 29, 2005 7:17 pm
Cool thanks!
