It is currently Mon May 25, 2026 5:17 pm
 Post subject: Rear end swap...
PostPosted: Mon Jul 25, 2005 8:00 pm
So if I got my info. right, the rear-end in auto-matic pups is lower than the 3.73 in the rwd diesel luv/pup. So if I did get the rear outta' that truck would the driveshaft still bolt up to the rear of the auto? And what of the rears in the impulses? The limited slip ones? What's their available ratios? And will the shafts bolt up?
