It is currently Mon May 25, 2026 6:48 pm
 Post subject: wheel offset
PostPosted: Wed Jun 29, 2005 6:53 am
Well, as some of you know I have a 82 LUV, but i'm getting new rims for it so I need to know what offset i need, i'm eyeballin' some unique wheel 96-seires. And do I need a special backside setting? And the lug spacing is 6-5.5" right? or is it 6-4.5"????
PostPosted: Wed Jun 29, 2005 10:17 pm
i have a 79 and yes it is 6 on 5 1/2 but i ordered 15x7 with a -9 offset and they look pretty good. it all depends if you going to lower it or keep it factory height. Im running 225/50's all around planning on dropping it 3" all aound but i wouldnt go with anything over -9 backspacing
PostPosted: Thu Jun 30, 2005 7:50 pm
Well i'm plannin on lowerin the front bout' 1"-2" maybe the back but I don't know where to get lowering blocks for it. or how to lower the back.
PostPosted: Thu Jun 30, 2005 8:58 pm
u can get any universal block set at the parts house. it will have directions included (not to difficult). front just lower torsion bars.
PostPosted: Fri Jul 01, 2005 8:19 pm
Is there a way to special order shocks for the front too? since if I lower the front the shocks'll bottom out b4 the suspension actuallly does.
PostPosted: Fri Jul 01, 2005 9:45 pm
you really shouldnt have a problem if the biggest your going is 2" but if you think you need them, once you get the front lowered to where you wont it with the torsion bars measure the whole shock as it sits. The auto parts store shop be able to match some up for you with your measurement.
