It is currently Tue May 26, 2026 2:53 am
 Post subject: Whats the difference
PostPosted: Sat Jun 18, 2005 10:47 am
Whats the differance between a 4 four bolt V8 and a two bolt.
 Post subject: 2bolt 4 bolt
PostPosted: Sat Jun 18, 2005 2:22 pm
some blocks can with 4 bolts per main bearing or 2 bolts per main bearing. like the chevy 350.Please dont ask which is better lol everyone has there opoin.Hope this helps.
PostPosted: Sat Jun 25, 2005 9:05 am
Not to confuse the issue but there are two types of 4 bolt blocks. First and most common is where all 4 main cap bolts are straight into the block. A splayed 4 bolt has the outer bolts installed at an angle pointing outward while the inboard cap bolts are still straight. If you find one of these at a swap meet or garage sale GET IT
PostPosted: Sat Jun 25, 2005 10:59 am
the splayed 4bolts are typicaly after market. Theres some machinists that can take a 2bolt block and make it a splayed 4bolt. And if yopur looking for a 4bolt small block, look at trucks. Almost all Chevy truck motors are 4bolt mains.
