It is currently Tue May 26, 2026 1:05 am
PostPosted: Tue Jun 07, 2005 7:33 pm
Is there a lot of modification that needs to be done and if so what would need to be done.
Last edited by Linktstriforcez on Tue Jun 14, 2005 8:16 pm, edited 2 times in total.
PostPosted: Wed Jun 08, 2005 2:14 am
Swap Specialist Mod
the chevy motor has the dist in the back of the motor, so you might not beabale to put the motor as for back as you would with a buick. the buick has the dist on the front of the motor, but the bellhousing is like the shape of and egg standing up, so youll have firewall clearance problems. id prolly go with the chevy v6 since the bellhousing ist so tall and you wont have to do alot of firewall mods.
neil
PostPosted: Wed Jun 08, 2005 6:07 am
If you could still get buick the kit to put the V6 in, I would say do it first, but I do not think they make a kit anymore.
With my buick V6 swap, all I had to do was knock the lip up about 3/4" on the tranny tunnel. There were no other mods done to the firewall, and I used the stock radiator.
In my opinion, I would say whatever was accessible. If you can find a Chevy V6 cheap, or a Buick V6 cheap. Do some price checking, and see how much you will have to spend on each engine.
Also, Do you plan to do alot of fabrication, or do you just want some more power with something that will fit?
If you plan on making the thing fast in the future, I suggest going ahead with the V8 swap.
03Cobra
PostPosted: Wed Jun 08, 2005 6:27 pm
I had Buick V-6 engines under the hood of my truck for over 18 years and i've never regretted building this setup. During that time, parts could be readily found for non computer controlled engines. But now, locating a correct distributor can set you back hundreds of dollars. If i were to do it all over now, I'd go with the Chevy 4.3 T.B.I. with all of the computer gear. A more modern transmission has overdrive and there's got to be a way to rig up the cruise control.
The sun is setting on the Buick V-6, The Chevy 4.3 is ripe for the picking.
Either way, a V-6 in a LUV is a great balance of power without alot of extra weight.
PostPosted: Wed Jun 08, 2005 6:47 pm
thanks for the info
PostPosted: Wed Jun 08, 2005 7:36 pm
I've been think about doing the Vortec 4.3 Swap but not sure of all the puter stuff i will need and I want to make it 4wd.
Jim
`79 LUV 2WD Stocky
`80 LUV 4WD Stocky
Users browsing this forum: Google [Bot] and 39 guests
