It is currently Mon May 25, 2026 11:24 pm
PostPosted: Tue Jun 07, 2005 1:04 am
is it just to slap on or what? what about that lock up converter thing and hows does that work? anything that i need to wire up? i want to put the 305 with a 700r4 so help me out guys
PostPosted: Tue Jun 07, 2005 1:22 am
i dont know if Wicked Mayhem put the motor in his truck, but hes got that TPI 305 with a 700r4. hed probably know all about that stuff. :D
you gonna put that 305 in your truck?
neil
PostPosted: Tue Jun 07, 2005 1:42 am
Compared to a typical TH350, the 700R4 is gonna need a throttle cable attached to the carb. This is not a "kickdown" cable like on some early transmissions. It's a throttle position cable that HAS to be hooked up for the trans to work. I believe it's called a TV cable?
Other than that, you can get a non lockup converter if you want. I believe you have to remove a check ball in the input shaft of the trans if you go with a non lockup so check with a trans shop on that one. If you want a lockup converter, it's easy enough to connect.
I can't think of anything else that's an issue, other than getting them to stay together. Oh, and the common RPM flash between 2nd and 3rd that some of them seem to have.
PostPosted: Tue Jun 07, 2005 1:48 am
yeah the cable thats hooked up to the carb is calle like the "throttle valve" cable. my friend just rebuilt his 700r4 and i hooked up all that stuff today. weird trannys.
arent 700s kinda weak though. i heard that id you put more than 300 hp to em thay start chewin up sprags and goin thru clutches. ?? 8O
neil
PostPosted: Tue Jun 07, 2005 11:35 am
Japanese Redneck
the 700R4 aka 4L60 is 2" longer than a TH350 so you may have to redrill your trans adapter. yeah you will have to set up the TV cable and make sure its adjusted right or it will toast the trans. later model trannys are called 4L60E (E for Electronic) and do not have a TV cable but I believe you might have to buy a controller for it for a non ECM application. TCI and B&M both sell a lock-up control for like $50 I think. Stay away from the earlier model 700R4's (pre 86 i believe). they only had a 7 vein pump vs the later model 10 vein pump and they had a weak intermediate sprag as well as less splines (weaker) on the intput shaft.
I had a built 4L60/2800stall in my 93 Z28 LT1 with a 150 shot on it. It lasted a pretty long time with severe street racing abuse... but quite honestly, my stock 4L60 lasted longer. go figure.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Jun 07, 2005 12:56 pm
Check out bowteioverdrives.com
PostPosted: Tue Jun 07, 2005 12:59 pm
Oops. bowtieoverdrives.com. Whats that i before e saying?
PostPosted: Sun Jun 12, 2005 7:24 pm
700s are alright but yes the earlyones are weak. If you cn finda Kcase from an 85 or later truck. hese ones are alot stronger. alsoyou can get lost firmer shifts out of em by adjusting the TV cable tight. This will trick the tranny into thinking your alwaysflooring the gas so the clutches wont slip as much and thus will generate less heat. what ever you do whith the 700 get the biggest trany cooler you can get and mount it whith its ow electric fan. Heat is even more critical whith these almost all failures are directly tied to heat.
Users browsing this forum: Bing [Bot] and 22 guests
