It is currently Mon May 25, 2026 6:02 am
PostPosted: Thu Mar 10, 2005 1:56 pm
what driveshaft will fit the stock rearend yoke?
will it need to be shortened?
or just change the u-joints on the stock and input yoke?
PostPosted: Fri Mar 11, 2005 1:19 pm
i was totally unclear on the question duh
i mean on a th350 trans will the u-joints hook up to the th 350 yoke
and to the stock yoke on the pinion?
PostPosted: Fri Mar 11, 2005 10:51 pm
You'll need to get a driveshaft built. The stock driveshaft diameter is too small to fit a G.M. flange. Find a G.M. driveshaft thats long enough and get the stock Luv flange mated to it. Find a driveline shop and ask them how they want you to measure the length of the driveshaft that they'll build. This will only last for a while because the stock rear end will eventually fail from the load put to it from the bigger powerplant. Keep an eye on the stock rear u-joint too because it about half the size of the G.M. unit.
PostPosted: Sat Mar 12, 2005 12:45 am
holy turds batman!!!!!
ok how about a different rearend ?
will a s-10 axle be short enough to get under there?
i have a second ass end for the truck but i dont want to blow it in a bad place! :(
like on the freeway
PostPosted: Sat Mar 12, 2005 1:11 am
the s10 rearend is a direct bolt in. put that sucker in there and have an all gm driveline made.
neil
PostPosted: Sat Mar 12, 2005 1:12 am
the s-10 axle is basically a direct bolt in and then a 2nd generation camaro driveshaft and you should be all set
