 Post subject: my engine hardly runs
PostPosted: Thu Mar 03, 2005 12:53 am
when i first built my engine, it ran like an ape. now it is slow, and stutters real bad. it sounds like it has an inconsistant miss almost. only when you rev it up. it sat for about 8 monthes, and never moved. now it doesnt run ver y good. i cleaned the carb and put new plugs cap and rotor on it, and it helped a little. i was revving it reall high when i was wheeling, and it just started acting real bad, so i pulled the distributor cap, and it broke the rotor and striped it out on the inside, so i got a new one and it runs alright, i dont know what to do. does anybody out there know what might help? thank you.
p.s. i took 8 inches out of the frame today, it is welded in the rear, tractor tires on the back and 29 swampers on the front, she should really go good now.
PostPosted: Sun Mar 06, 2005 9:35 pm
did the cam go flat???
