 Post subject: Hooker Trans Mount Q
PostPosted: Tue Jan 18, 2005 7:16 pm
Anyone got a pic of the Hooker TH350 or TH400 mount?
I'm just trying to figure out what makes it so exspensive. I got real lucky & found a Hell of a good deal on a set of Hooker SBC mounts, & can't figure out whats special about their trans mount.
'46 Studebaker truck "project"
'90 Trooper 4X4, 2.6L 5 spd
PostPosted: Tue Jan 18, 2005 8:47 pm
looks pretty much like....
Nothing special. My truck has the original mount with a section of channel welded to the underside long enough for the correct length and then has the two slots in it. I can post a pic of it if you want, but it won't be till Thurs.
Resident lurker
PostPosted: Tue Jan 18, 2005 8:59 pm
Thanx. And I would like to see a pic of your transmission mount when you can get to it, as well. :D
PostPosted: Wed Jan 19, 2005 11:39 pm
Cool pic, I would also be interested in seeing your trans mount-thanx
PostPosted: Wed Jan 26, 2005 2:39 pm
Ok, so it was more like a week from last Thurs! :D But here it is.... It worked fine but not sure if I'm going to use it or not when I put the truck back together. The only diff from the first to second pic is the spacer...
Resident lurker
PostPosted: Thu Jan 27, 2005 7:30 am
Simple & cheap- I like it. Thanx for the pics!
