It is currently Mon May 25, 2026 1:22 am
 Post subject: 72-74 v8 kit
PostPosted: Mon Jan 10, 2005 12:25 am
I have a couple extra engine mounts and tranny mounts for 72-74 luv,
with these mounts there is no need to to remove the front radiator support, but it needs to be notched though, there is enough room for a victor junior intake and a 6inch tall air cleaner,and thats with the stock hood, you don't need to run a electric fan either. So if anyone is interested in these or any questions let me know. Also allows the use of block hugger headers.
PostPosted: Mon Jan 10, 2005 12:36 am
How much you lookin to get for them??
PostPosted: Mon Jan 10, 2005 12:48 am
Haven't even thought of that, just checking to see if anyone was interested in them.
I think around 40 to 60 depending on shipping.
I can provide instructions if needed
PostPosted: Mon Jan 10, 2005 5:58 am
Are they the mounts from Don Hardy?
Resident lurker
PostPosted: Mon Jan 10, 2005 1:20 pm
No they are not don hardy, these mounts I made cause i didn't like any of the mounts made, so i designed my own, I've seen other mounts like hooker's and so on and couldn't justify paying hundreds of dollars just to mount the engine and useing headers that go over the frame, and those other mounts make the engine sit higher, So i just happen too make soome extra ones awhile back and figured if their is someone that doesn't wanna use and spend big$$ on another kit, they can have this as an option.
PostPosted: Mon Jan 10, 2005 9:16 pm
Just wondering cause I've got a set of Don Hardy mounts that use the original luv mounts for the v8 swap. They aren't at all like the hooker mounts (got some of those too.) I imagine the DH mounts I've got are worth a couple of bucks since they haven't been made in quite a few years...
Resident lurker
PostPosted: Mon Jan 10, 2005 9:31 pm
Well I am thinking of starting another V8 luv project for this spring so send me a PM of what you wouold like to get out of them! Thanks again!! T.
PostPosted: Mon Jan 10, 2005 11:13 pm
just to let you know these only work on 72- 74, un less you wanna switch your frame to use them.
PostPosted: Mon Jan 10, 2005 11:29 pm
cool, my truck is a 72, and I also built my own motor mounts, but I made them a little to short and had to beat in my header some on the driver side to miss my steering rod :evil: So let me know :wink:
