 Post subject: V8 and 4 speed
PostPosted: Fri Dec 31, 2004 4:08 pm
Has anyone done a V 8 swap with a manual trans? And if so which trans did you use and how well has it worked?
Is it too much torque for the frame if you get rough on it?
PostPosted: Sat Jan 01, 2005 6:52 pm
LUVTruck.com's Cornholio
I dont have a manual tranny (but a th350) but the frame on mine takes the torque well.
PostPosted: Sat Jan 01, 2005 11:52 pm
The frame is the toughest part of the truck 8)
Lots of folks here have healthy v8's in their truck with no mods to the frame.
I'd also like info on manual tranmissions in v8 luvs. How difficult is it to use the existing hydraulics (older models) for the clutch? Or would it be better to go with a cable?
PostPosted: Wed Jan 19, 2005 5:04 am
ive got a 4 spd muncie behind a 406 sb and it does just fine. had to make trans mount longer by 5 inches though
http://bonsaint.com/luvalbum2/index.htm
more pics of my 76 406ci 4 spd posi.
PostPosted: Sat Jan 22, 2005 8:19 pm
Here's what the Hooker conversion directions states:
NOTE: IF A MANUAL TRANSMISSION IS TO INSTALLED AND HOOKER CLUTCH CABLE BRACKET IS TO BE USED, IT WILL BE NECISSARY
TO BUY AND INSTALL A 1975-77 MONZA V8 BELLHOUSING AND THROW OUT BEARING ARM. IF A HYDRALIC CLUTCH
ASSEMBLY IS TO BE USED, REPLACE STOCK MASTER CYLINDER CLUTCH WITH A CHEVY TRUCK SLAVE CYLINDER #EW3447
EIS PART NO. FABRICATE A BRACKET TO BOLT SLAVE CYLINDER AS CLOSE TO STOCK BELLHOUSING AND IN STRAIGHT LINE
WITH THROW OUT BEARING ARM.
Sounds like adapting hydraulics to the clutch is easier than hunting down a bell housing and swapping parts.
 Post subject: ???
PostPosted: Mon Jan 24, 2005 12:03 pm
Never knew you could replace a Master Clutch Cylinder with a Slave Cylinder! How would that work? or am I reading it right?
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Mon Jan 24, 2005 4:14 pm
I think it's a misprint on their part. It's more likely that they would suggest that you swap slave cylinder and fab a bracket to fit.
