It is currently Mon May 25, 2026 12:08 pm
 Post subject: clutch ?'s
PostPosted: Tue Nov 30, 2004 7:01 pm
I got a saginaw 4-speed tranny and i dont know how to hook it up. I would like to use the hydraulic set up thats on the truck but the slave cylinder wont fit. If any knows how to make it work, please let me know.
PostPosted: Wed Dec 15, 2004 11:54 pm
Swap Specialist Mod
what kind of bell housing does it have. you might have to run a cable clutch.
PostPosted: Thu Dec 16, 2004 1:55 am
I dunno about the 4spd specifically, but you can get hydraulic throwout bearing setups for a lot of common trannies. It means spending quite a bit though, I recall them costing in the $300+ range. Your other option is to find a slave cylinder that fits a little better and match up the hose ends. Might need to fabricate mounts as well, but it would probably be cheaper than the hydro bearing setup. I know it would be cheaper to upkeep should you ever need to rebuild it. Anything Isuzu has a fair shot of bolting up to your LUV fluid lines, but I'd have no idea if any of them would fit your needs. Impulses, I-Marks, 87+ Troopers, rodeos, pickups would be candidates.
If you do find a cable setup is the way you need to go, you should be able to swap the pedal and bracket from a 78 or newer LUV for your fluid setup. The fluid pedal is designed to push so the bracket and pedal are completely different than the cable pull style. The bracket is no picnic to pull out, but I was able to get mine out pretty easy through the opening from the gauge cluster. It would pay to gusset up the attachment for the clutch pedal on your donor bracket, they tend to crack/bend/break fairly often. (The reason mine came out actually)
PostPosted: Sun Dec 19, 2004 12:53 am
i have a mechnical clutch setup with a cable clutch gearbox, but i wanted to go hydro. i just fabbed a racket to bolt on the sie of the box for the slave to push towards the engine bay. drilled a hole in the pedal and the firewall and bobs ur uncle
