 Post subject: Weber 32/36 DGV Jetting
PostPosted: Fri Dec 17, 2004 10:35 am
I know some of you guys have Weber 32/36 DGV's on your trucks...and I was wondering what jet sizes you were using? Also, info like avg ambient temp and elevation would be helpful, as well as recommendations for tuning the secondary barrel. The carb I have has
MAIN PRI 140 SEC 135
IDLE PRI 55 SEC 50
AIR PRI 165 SEC 160
and is on a fresh 72 Luv motor at around 260 ft above sea level, with an average temp of say, 45 degrees right now.
One last question...anyone know where I can get the idle step up linkage for the manual choke? Not avail. from Weber anymore says NAPA...
Thanks guys
PostPosted: Sat Dec 18, 2004 8:30 pm
Luvtruck.com Wookie
this is from an old post......
Quote:
my jet set showed up today......
here's what was in my truck when i got the carb.
larger numbers are the secondary side:(these are factory 4 cyl baseline jets)
air 160/170
idle 60/60
mains 140/140
here's what they sent me:
air 170/180
idle 55/55
mains 150/170
i live at 2200 ft elev. and the truck has a header, electronic ignition, intake porting for the weber(polished) and a 3000+rpm cam to go with the weber
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sun Dec 19, 2004 12:47 am
alright. thank you very much, will try that setup and maybe a step or two up.
