 Post subject: transmission mounts
PostPosted: Thu Nov 18, 2004 7:48 pm
what kind and where should i get a transmission mount or cross member for a luv with a 350 and a turbo 350 automatic tranny
PostPosted: Thu Nov 18, 2004 7:53 pm
im going to just cut mine out(the one in it) and drill a hole for the 350 turbo, then im going to put it in with the cross member connected and weld the cross member where ever it ends up??? I read this in the info section of this site\
PostPosted: Thu Nov 18, 2004 11:14 pm
I don't recall reading that anywhere???
All you need to do is either modify the existing bracket or buy a Hooker trans mount or use the stock one as a template and build a new one.
It isn't difficult If you'd like I could take some pics of the modified one that was on a truck when I got it...
Resident lurker
 Post subject: Trans Mount
PostPosted: Fri Nov 19, 2004 10:18 am
I have a T400, stock crossmemeber, I use the Energy Suspension GM trans mount, fits perfect. I don't know exactly what the dimensional differences are with the 350/400 but they have to be pretty close?
PostPosted: Fri Nov 19, 2004 6:50 pm
Dr. Luv wrote:
im going to just cut mine out(the one in it) and drill a hole for the 350 turbo, then im going to put it in with the cross member connected and weld the cross member where ever it ends up???\
This has got to be the dumbest statement I have seen on the board so far :roll:
If you don't have INTELLIGENT info, then you really don't need to be posting, that's just my opinion. :?
