It is currently Tue May 26, 2026 12:48 am
 Post subject: G180 head on G200 block?
PostPosted: Sat Nov 13, 2004 5:56 pm
I don't know if this is a stupid question but just got a luv and the head is blown and my local junk yard has a good G180 head the engine in the luv now is a G200. Im just wondering is it possible.
Thanks
cappe00
PostPosted: Sat Nov 13, 2004 7:17 pm
I am unsure of this myself, but hopefully someone who knows for sure will come along :wink:
PostPosted: Sat Nov 13, 2004 7:29 pm
Pretty sure you can bolt it on... however if there is someone that can tell you for sure and for possible problems, 800xl is the man you need to speak with.
Resident lurker
PostPosted: Sun Nov 14, 2004 2:12 pm
I know I've heard of going the other way, but I can't recall anyone putting the 180 head on a 200. Kuranosuke is the motor rebuild expert, maybe he'll stop in and comment on this. I believe the 200 head has a bit bigger chamber on it, so going to the 180 head would tend to up compression. More power, but more picky on the gas it will want to run. Might have to time it a little less advanced too.
If you haven't gotten yours apart, it is probably just the gasket that is leaking. It is possible the head cracked or warped enough to be unfixable, but usually it is just the gasket. That said, I just finished head work on a truck that did have a cracked head. ;) If your budget allows, take your current head in to a machine shop and have them pressure check it. It may be good enough and you could avoid the worry. It would be worth getting the valves/guides done, but it depends on if it is worth the price.
PostPosted: Sun Nov 14, 2004 4:10 pm
it's supposedly possible... click click click
http://forums.luvtruck.com/viewtopic.php?p=4072#4072
PostPosted: Sun Nov 14, 2004 9:51 pm
This being the case..... 8O just may be trying this myself w an engine I have in pieces right now, thanks so much for the info 8)
