It is currently Mon May 25, 2026 1:22 am
 Post subject: 86 pup tranny
PostPosted: Fri Oct 29, 2004 8:17 pm
this is it if a 86 izuzu pup tranny will work for my 5spd convertion i am picking it up tomarrow i just want to know if that tranny will work thanks for the input.
kevin
PostPosted: Fri Oct 29, 2004 8:54 pm
If you mean bolting up to g-180 or g-200 engine.....YES, it will work
PostPosted: Sat Oct 30, 2004 12:38 am
hell ya thats exactly what i need to know. what will i need to take when i get it to make it work on my luv that is one other thing i didnt ask but wanted to know.
thanks again
kevin
PostPosted: Sat Oct 30, 2004 7:47 am
It bolts up the the motor, but you'll need some welding done to the cross-member from what I hear and to have your rear drive-line shortened some. . . 4 inches I thinnk cause the tranny is longer with the extra gear it in. You also have to make a new park brake bracket. Then you have to cut out the new shifter hole.
1980 Luv Mikado 4X4
PostPosted: Sat Oct 30, 2004 8:00 am
Luvtruck.com Wookie
that's a 2wd right? take a tape measure with you and hook the backing plate and measure to the flat plate that the rear of the driveline attaches to.
do the same on your truck and then do the math(mine was two inches different(shorter) don't worry about being precice on the measurment just get it to the 1/4 inch.
get the driveline chopped ($100-150)and get ready to have some greasy fun.
do yourself the biggest favor and get a new cluch to put in while it's apart.
the mounts off the tranny i scored were the same ,but just to make sure measure by hooking the backing plate and get the number to the mount. if it'a within a 1/4 inch start tearing it all apart.
GOOD LUCK!!!! and don't get frustrated.......... :2gunfire:
TiLtEd wrote:
Boobies!!! :D
