It is currently Mon May 25, 2026 4:09 pm
 Post subject: Shimmed it
PostPosted: Thu Oct 14, 2004 3:04 pm
I shimmed one side of the starter and It doesn't drag anymore!!! But I now often have to use my start stick (Long Screwdriver) to start it. Do I need to get a push button to start it. It's getting pretty embarrassing having to go under the hood to start it.
PostPosted: Thu Oct 14, 2004 7:39 pm
put a ford style selonoid on it and a jumper wire at the starter ... should fix the hot soak problems
GOTTA GET A NEW LUV!!!!!!!!!
