It is currently Tue Jun 30, 2026 4:25 pm
 Post subject: 700R4
PostPosted: Wed Nov 27, 2002 8:26 pm
The Luv truck I plan to convert is a diesel is there any differences. I would plan to use a 350 backed by a 700R4 is it difficule to modify the trans mount.
PostPosted: Wed Nov 27, 2002 11:35 pm
The 700R4 takes a different trans mount than the TH350 or TH400. I made my own mount. It wasn't too difficult but it did require some cutting and welding.
PostPosted: Thu Nov 28, 2002 3:16 am
I put a 700R4 in mine and i just cut the trans mount back about an inch and drilled 2 new holes...by the way i used the hooker trans mount because thats all i had. be sure you measure it just right because i cut off about a half an inch too much. it was a pain in the ass to fix it with another piece of steel
