It is currently Tue Jul 07, 2026 3:17 pm
 Post subject: tire clearance
PostPosted: Thu Sep 23, 2004 4:38 pm
any body now how to move the front wheels in an inch or so? i got some 16x8 wheels with 205/55/16's but the hit the front fenders....
1-2 it's not new, 3-4 shave the door, 5-6 learn some trix, 7-8 make it scrape!, 9-10 show your friend!
PostPosted: Thu Sep 23, 2004 4:59 pm
How good are ya with fender work?? 8)
PostPosted: Sat Sep 25, 2004 5:06 pm
you're best bet is to get a rim with sufficient offset. however if you do that then you'll also throw off the load bearing point of youre front hubs, if you go too much you can damage bearings. you see that a lot in those low ride pimp wagons :-)
