It is currently Mon Jul 06, 2026 2:46 am
PostPosted: Sun Sep 12, 2004 8:49 pm
Luvtruck.com Wookie
yaaaa.....i just finished the ignition swap today.
i have been wondering where the bottom end went after i put the weber on,well it was sitting in an 81 luv.
the power has increased across the top end range and the throttle has no flat spot at takeoff. this was the first time i have ever pegged the stock speedo.
if any one need any help wiring there setup, i can help. was pretty simple.
thanks for the help mepr, i needed my suspisions confirmed. as always this site has been an invaluable source of information.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sun Sep 12, 2004 10:10 pm
Is everything you did the same as the instructions given in the information section of the site? Was there anything different except that you used an 81? I plan on doing this too, soon as I can find parts. Thanks, good to have someone do it before you, makes it easier for the latecomers.
1980 Luv Mikado 4X4
PostPosted: Sun Sep 12, 2004 10:29 pm
Luvtruck.com Wookie
some things in the article were a little different since i belive mepr did it with new parts.
i took the setup out of the donor with the harness intact.
the harness for the ignition conisists of a green plug a white plug and a ground.
hook up the ground then clip the green plug's wire off at the positive post of the coil....us ethe cliped off wire to plug the white plug off then hook the ignition wire to the positive side of the coil. drop the dist in and hook it up to the module via connecter and set up the secondary circut(coil and plug wires)
boom you're done.
i'll post a few pictures for so it can be documented
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sun Sep 12, 2004 11:07 pm
Ahh, excelent... Pictures make everything easier.
1980 Luv Mikado 4X4
PostPosted: Sun Sep 12, 2004 11:11 pm
Banishment Pending
I would like more info on this because more power is always better, if you could send me a compleat message of what all it took to do this that would be so cool, thanks
PostPosted: Sun Sep 12, 2004 11:15 pm
Or at the least, the differences between what you did and the swap that's already in the information section. . :)
1980 Luv Mikado 4X4
PostPosted: Tue Sep 14, 2004 3:44 pm
is this some form of eletronic igniton?
http://www.centuryperformance.com/detai ... AL-4765501
just wonder in if not i am going to go the same way you did.
kevin
PostPosted: Tue Sep 14, 2004 10:44 pm
Banishment Pending
HOLY SHIZ KNAP, that sucker is a bit expensive!!!!!!! man i wounder if it is realy electronic ignition? same question as RMS, is this electronic ignition or just a really expensive disripitor. and one other has any one ever tried this thing out?
 Post subject: Unilite
PostPosted: Wed Sep 15, 2004 8:02 am
The distributor in the ad is a MAL-4765501 which according to the Mallory catalog is a breakerless electronic, vacuum advance distributor with a three wire hookup. The same catalog also says the part doesn't come with a drive gear. Too pricey for me...
PostPosted: Wed Sep 15, 2004 1:41 pm
ya its just a bit too pricey for me.
