It is currently Mon Jul 06, 2026 1:48 am
PostPosted: Tue Sep 14, 2004 7:16 pm
I read that to use the hooker motor mount brackets, use 70-79 camaro mounts. when i got the hooker mounts (12606) the bolts that came with it are too short. i can use the original bolts but the mount brackets are alot wider than the hooker mounts. No instructions came with the Hooker mounts and it did not specify what mount brackets to use. (I think I read about using camaro mount brackets on this site). what did ya'll use?
PostPosted: Wed Sep 15, 2004 6:20 am
MOROSO solid mounts on engine
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Wed Sep 15, 2004 3:55 pm
I used energy suspension mounts for the motor and trans. I'll need to find the part #s for you but it can take a few days.
PostPosted: Wed Sep 15, 2004 7:19 pm
Homemade! 8)
Resident lurker
PostPosted: Thu Sep 16, 2004 9:13 am
Japanese Redneck
Moroso
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Sat Sep 18, 2004 10:27 pm
http://store.summitracing.com/default.a ... g&x=16&y=6
This is what i got in my conversion. There's a gap between the mount bracket and the motor mounts themselves (about a 1/4") The Hooker headers just clear the mounts. The bolts i got with my Hooker kit were more than long enough. Using correct length, grade 8 bolts will fit the bill.
