It is currently Mon May 25, 2026 6:49 am
 Post subject: MSD Ignition experts
PostPosted: Sat Oct 09, 2004 1:40 pm
I'm looking in to replacing the stock H.E.I. distributor on my small block. The H.E.I. that i have right now was a 60.00 deal that got the truck to work. But it has it's problems. I replaced the weights, bushings and springs to eliminate the pinging. It helped alot but it still isn't quite right. So i decided that the new motor should get a new distributor. It already has a new carb so it only makes sense.
I've elected to go with a MSD system. The motor itself is just a slightly modified stock motor so im not looking for an elaborate setup but it would be good to have the option to add upgrades to the components i've got. If anyone can shed some light on this, it would be most helpful. Thanks!
PostPosted: Sun Oct 10, 2004 7:26 am
Blue, I'm not exactly an ignition expert, far from it, but I can tell you what I use. I have a stock rebuilt HEI with a hypertech coil. I run a MSD 6AL box with adjustable rev control. Pretty simple, and it works. I've never run one of MSD's distributers, although I'm sure they're great. When I installed this stuff, I noticed the plugs burn cleaner and the truck starts easier. I'm also running Accel 8.8 mm wires. Now, I know you don't race yours, but my setup is very mild. I know plenty of guys who run stuff way more radical on the street. Anyway, there ya go.
PostPosted: Sun Oct 10, 2004 8:22 am
The thing about the distributor i have right now is a very used unit. I was told that it was rebuilt. In all actuallity it was a distributor built from a bunch of spare parts. It needed a new cap and rotor right off and the weight bushings were shot. It does have an MSD coil so that led me to believe that it was going to work flawlessly. It does function well enough to drive but there's some slight pinging at part throttle that i just cant get rid of. So im looking to get out from under the problem by replacing the ignition. This motor is very fresh and i dont want anything to go wrong with it, plus i want it to run at it's best for what it is.
PostPosted: Sun Oct 10, 2004 10:07 am
just a personal opinion!!
get a MSD 85551 dist.
get a 6AL box
get a MSD coil
problems with ignition will be gone
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Sun Oct 10, 2004 11:43 am
How much would that sent me back?
PostPosted: Sun Oct 10, 2004 6:18 pm
close to $500.00
but well spent
PostPosted: Sun Oct 10, 2004 8:14 pm
Well, I have the 6AL, so I guess I have that part covered. I understand what your saying, Blue, about your HEI. I rebuilt mine myself with all new parts-so I knew it was good. If I had the bucks at the time, I probably would have considered a better distributer. But, it ain't cheap. Spanky is right, chances are your probs would be a thing of the past. I have a mild small block that freely revs to 6800, so my stuff seems to work. If you can spend the $$$, I would buy good stuff.
PostPosted: Mon Oct 11, 2004 3:29 pm
I just bought a whole new ignition system for mine. Accel breakerless, billit distributor, Accel 300+ box and Accel 375+ control module. It is awesome, should have done it a long time ago.
PostPosted: Mon Oct 11, 2004 3:40 pm
Pinging? Pardon my ignorance, but what is pinging?
PostPosted: Mon Oct 11, 2004 4:27 pm
tapping in the valves caused by the timing to be off... usually because of advance problems... or bad gas.
PostPosted: Mon Oct 11, 2004 6:00 pm
Whats the difference between a 6A and a 6AL box? After doing some research, i have to agree with Spanky on going with the 85551 dist. This particular dist can be used with a number of boxes and it seems that the AL unit is most common. Whats the reason for going with the 6AL?
PostPosted: Mon Oct 11, 2004 9:23 pm
i think the 6al you can install a rev limiter chip and the 6a you cant. again i think. bryan
PostPosted: Mon Oct 11, 2004 10:19 pm
Yep!
PostPosted: Wed Oct 13, 2004 9:08 pm
yea the 6al has the rev limiter built into the box. with the 6a you would have to run an external rev limiter if you wanted one that equals more wires and hassle. im not sure with dist. your looking at i don`t have the catalouge in front of me. but if you plan on mostly steet driving get one with the vacuum advance it will help with gas mileage in cruise situations.if it was just a weekend cruiser i wouldn`t worry about the vacuum advance.some companies make there vacuum advance canisters adjustable as well
Users browsing this forum: Bing [Bot] and 22 guests
