It is currently Sun Jul 05, 2026 2:27 pm
 Post subject: trani cooler question
PostPosted: Sun Aug 29, 2004 10:57 pm
So I am lookin on ebay, and there are alot of diffrent size coolers. ie. 30"-24"-18"-15" and so on. Any how, what do you guys rec. for a th350. and do you rec. putting a fan on it or just putting it somewhere that the wind will blow on it? here is one, but damn they are spendy!
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=46095
PostPosted: Mon Aug 30, 2004 7:12 am
OG Lifer
That one is pricey because of the fan. You can get a medium sixed cooler from autozone, and mount it in front of the radiator. The kit has little zip ties that go through the radiator to hold the cooler in place. Easy install, and I would suggest capping off your original cooler ports on your radiator unless you have a rad for a manual tranny.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Mon Aug 30, 2004 10:28 pm
well, with the Rad. fan, there will be no room for anything else in the front of the Rad. Any other suggest. welcome
PostPosted: Mon Aug 30, 2004 11:06 pm
OG Lifer
It can be in front or behind the radiator.
PostPosted: Tue Aug 31, 2004 12:43 am
well once I get the rad. mounted I will see, but off the top of my head now, I would say that I will not have the room on either side.
PostPosted: Tue Aug 31, 2004 7:15 am
OG Lifer
Then the one with the fan mounted to it is the only way to go.
PostPosted: Mon Sep 06, 2004 8:34 am
I got a "frame rail trans cooler" from Summit. It was less than $40 and is designed to mount about anywhere.
