It is currently Fri Jul 03, 2026 8:47 pm
PostPosted: Mon Aug 02, 2004 4:09 pm
Luvtruck.com Wookie
i just finished my rebuild and wanted to hook up a makeshift smog system w/ my weber carb.
i have a semi stock manifold (all the ports are there except the egr system)
the evaporation system and the pcv system are my main concerns.....
i need to know how to hook up the little valve cover vent , oil pan vent and the tank evaporation system.
are they suposed to get straight vacume? do i need a pcv valve to hook the valve cover vent to?
how do i hook the canister up without having a bowl vent?
i already have a breather cap and the large pcv tube from the valve cover hooked up to the air cleaner assby on the carb
TiLtEd wrote:
Boobies!!! :D
Last edited by where's all the luv at? on Tue Aug 03, 2004 5:34 pm, edited 1 time in total.
PostPosted: Tue Aug 03, 2004 5:33 pm
Luvtruck.com Wookie
Hmmph.......i guess there's no one that feels that they can help tackle this issue........ :(
i do know a little about the subject but i guess i need to become a smog expert, but that's okay......I like to learn. 8)
knowledge is cool
TiLtEd wrote:
Boobies!!! :D
PostPosted: Tue Aug 03, 2004 10:59 pm
most of the smog stuff hooks up to the intake manifold. its hard to find out where all the lines go cause theres not a real good diagram. best bet is to find someone on here that still has all their smog stuff. maybe they can take a pic.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Wed Aug 04, 2004 12:03 pm
I think the tank evap unit goes into the air cleaner not straight vac. The valve cover vent goes right down to one of the manifold ports on the inner side from the carb. I'll have to look at which one because I believe it is actually specific. The book mentions a sort of a PCV valve like device in the intake manifold.
PostPosted: Wed Aug 04, 2004 5:20 pm
Luvtruck.com Wookie
my adapter plate is what's keeping me from using the pcv spot on the manifold...have any of ya'll seen a pcv valve that goes in-line on 1/4 vac hose?
i've got a spot to plug into but it's straight vac.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Aug 04, 2004 7:29 pm
Luvtruck.com Wookie
WOW........ i got the pcv system set up and it really seems to be running better. i got an obvious increase in power now that the pcv vac is regulated.
thank you for the help guys......i don't think this project could've been possible without all the help and encouragment i've gotten here.
TiLtEd wrote:
Boobies!!! :D
Users browsing this forum: Google [Bot] and 26 guests
