It is currently Fri Jul 03, 2026 1:02 pm
 Post subject: Driveshaft loop question
PostPosted: Tue Jul 20, 2004 12:25 am
Is it legal to build a loop using the crossmember that just aft of the trans crossmember? Or does the loop need to be mounted at a specific point in relation to the driveshaft? At some point i will end up at a drag strip someday and i'll need to have some stuff dealt with.
PostPosted: Tue Jul 20, 2004 2:41 am
isn't ratnluvs right off his crossmember? :?
PostPosted: Tue Jul 20, 2004 2:47 am
nevermind :oops: maybe it does have to be in the center of the driveshaft :?
PostPosted: Tue Jul 20, 2004 6:16 am
Thats not the one I ended up using, but the other one is in the same location. I ended up going with a four link and used a Art Morrison loop made out of round tubing. Looks a whole lot better. I would not swear mine is in the legal location for the strip. It would be best to check the rules,but I do believe the list location from the end.
stripped and just a memory!
PostPosted: Tue Jul 20, 2004 9:57 am
Japanese Redneck
I believe NHRA rules say its supposed to be 6" from each end of the driveshaft.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Jul 20, 2004 10:32 am
Forward and aft end of the shaft?
 Post subject: drive shaft
PostPosted: Fri Jul 30, 2004 10:17 pm
the loop goes in the front and you dont need one unless you run a slick
NHRA says only if you run a slick you need a hoop
