It is currently Thu Jul 02, 2026 4:06 pm
PostPosted: Wed May 26, 2004 4:52 pm
hey guys. havent been around fer awhile, school and a bitchy girlfriend where in my way. now ones almost finished and the others galdly done with. but about my truck. i was wondering what kind of and engine to put into my truck. i dont want a gas guzzler but when i push the pedel i want the tires to turn. i know that its not cheap but that also is a factor in what i need. i really appreciate all the help i got with my carb problem too.
PostPosted: Wed May 26, 2004 11:29 pm
a 22R from a toyota would be a good upgrade if you want to keep a 4 banger. good on gas, great aftermarket support, and will toss you back in your seat if you hop up the engine a bit(cam, header, weber carb etc).
PostPosted: Sun May 30, 2004 12:06 am
Hey thanx fer the input but my dad just said that hell lemme have the 350 outta his other truck so im gonna see how that works.
PostPosted: Sun May 30, 2004 3:49 pm
ok Cameron, I dont know your age but the first thing in hot rodding you have to learn is ...... performance and horsepower/ hotroddingand crusing all do not have a gas milage rate. milage and rodding are not in the same class. you either want to go fast or you want to get the milage.... gotta learn that real fast
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Mon May 31, 2004 7:29 am
If ya not in for the V8 you could always think of a 4 cyl turbo. Still get decent fuel milage and also have a fair amount of power there when you want it. A pretty cheep import engine should not be to hard 2 get or a half cut. SR20DET nissan or VR4 mitsubishi to name a couple.There should be heaps of different thing's youcan choose from. cheers!
CRAIG
PostPosted: Mon May 31, 2004 9:13 pm
I think you could performance tune the motor you have by grabbin a weber carb, doing an adjustment on the valves, and you should be set. I could always get my 80 4X4 to squalk the tires in forward and backwards.
Plus I got kick ass mileage.
PostPosted: Thu Jul 08, 2004 8:36 am
the main producer of hp is the heads! they must flow air! the more air you let in the cylinder the more power you will produce! you can achieve a lot of power on demand while still keeping somewhat good fuel economy by porting the intake, head(s), and throwing the stock exhaust manifold as far as you can..... install the header(s). a nice mild street/ strip cam couldn't hurt either. a lot of quality engine shops have flow a flow bench. you can calculate the horsepower and engine rpm by simply flowing the heads. that'll give you a pretty close idea of the rpm at witch the engine will produce the most power and where torque and hp begin to drop off. (shift points) before you even have the engine assembled! I'd also suggest having the vehicle dyno tuned to fine tune any engine adjustments. Its a small price to pay to have a perfect performer.
