It is currently Wed Jul 01, 2026 4:42 am
 Post subject: 351C swap with C4
PostPosted: Tue May 11, 2004 1:55 pm
Has anybody ever done a 351 Clevland with a C4 into a luv? Please let me know what it may involve for me to do.
 Post subject: 351/C4
PostPosted: Tue May 11, 2004 3:05 pm
Thats a FORD?
Just kidding, I'm sure it is very similar to stuffing the sbc in.
PostPosted: Tue May 11, 2004 4:40 pm
probably not much more involved than swapping in an sbc, might be easier for clearance because the distributor is in the front of the engine
PostPosted: Wed May 12, 2004 4:24 am
I agree with kyle, it should be easier because of the dist location, and the angle of the heads should give a lil better clearance of the fenders.
PostPosted: Wed May 12, 2004 1:13 pm
The 351C is a wider engine than a sbc. I think someone else was going to try doing something similar, but was having steering shaft clearance issues. Try a search on username RBG.... or search for 351...
http://forums.luvtruck.com/viewtopic.ph ... hlight=351
There's a link that might answer a few questions.... ^^^^^
PostPosted: Wed May 12, 2004 4:47 pm
oops, sorry, thinking about the wrong motor..... there is a guy in augusta georgia that makes a kit to eliminate the problem with the steering shaft, its a geared system which allowe you to move the shaft to a location which would allow you to put a wide girth motor into the compartment. i'll try to find the site for you if you have that problem
PostPosted: Wed May 12, 2004 5:22 pm
mad_sax@hotmail.com is RBG Racing. Yea, they were trying to do the same thing. Drop them an e-mail and ask them what they were up against. Also you can talk to Joey Quinn (Q Crazy). He's got a 302 setup so he may have some insite on the bigger motor.
PostPosted: Wed May 12, 2004 9:37 pm
isn't the 351 windsor a bit smaller(dimension wise) than a 351 cleveland?
