It is currently Wed Jul 01, 2026 7:11 pm
PostPosted: Thu Apr 29, 2004 2:47 pm
I need some help. Does any one have any specifications for a 350 engine swap? I have a 1976 Luv 2-wheel drive. What year 350 works best (if it matters) what transmission and rear end should I be looking for? I will be purchasing a new crate engine. Any info on new brakes would also help...
Thanks for all the help and support.
Ready to have some fun,
Mark
wall2705@bellsouth.net
 Post subject: 350 swap
PostPosted: Thu Apr 29, 2004 5:09 pm
Any model small block/crate motor is fine. Trans, everyone has their own favorites. I have a turbo 400 in mine, I think many prefer the 350 but as far as fittment they are the same. Rearend can be more of a pain if you want something 'Real' good. There are some smaller, cheaper options.
I am in the process of dumping way too much money into a completely brand new 9".
PostPosted: Fri Apr 30, 2004 4:52 am
http://www.luvtruck.com/Information.htm
go there and pick on the V8 info article.
if you don't have acrobat reader then get it.
that article should tell you everything you need to know....and if it doesn't you allways have this board! :D
03Cobra
