It is currently Tue Jun 30, 2026 10:37 am
 Post subject: 9" housing for RATNLUV
PostPosted: Sat Oct 19, 2002 6:38 am
I got my housing back from Moser Engineering and I would like to say that I highly reccomend them to anyone considering having a rearend built.Quick turnaround,great work and notified me about a slight problem with my housing before work was started.They was able to use the one I sent and I am going to be back on the road shortly.
I have changed and went to a 4-link and bought rear frame rails and coil overs instead of using the leaf sprigs.The 15 x 12 weld wheels and 29 x 15.50 Mickey Thompsons arrived a while back.I decided I am only doing this once and I am doing what I really want ,even though it is going to take a little longer.
stripped and just a memory!
 Post subject: mosier
PostPosted: Sat Oct 19, 2002 10:38 pm
mosier does good work in a short amount of time.Had them cut and respline my axles out of a 9 ".Should get my frame built SOON and will have pics of my little luvondope. 31x16.5 et streets,15x12 weld rodlites,9" with coilovers. :drinking:
PostPosted: Sun Oct 20, 2002 5:37 am
I started to have a set of axles shortened and resplined but by the time I had them shortened redrilled to my bolt patteren and turned down for the brake drums I am using it was almost as much to get new ones.
I moved it under its own power yesterday to my dads garage.There is still a lot of work before I will be driving it again but it sure felt good to drive through the yard.
I still have to get a fuel cell and a few other thing so I can go back to the strip in the spring and see what it will do.I want to make several passes both with and without the nitrous and then it will just be a driver.I put a Lunati nitrous cam in it when I built the engine and bought a Nos sniper kit.But I just got to know!
PostPosted: Mon Oct 21, 2002 5:26 am
RAT you better put some slicks on that thing before you throw the oxide to it! from that ride I took without the juice, it will most likely blow those M/T's off with it!
03Cobra
