It is currently Thu Jul 02, 2026 11:36 pm
 Post subject: pontiac 400 in 74 luv
PostPosted: Fri Feb 13, 2004 7:36 am
has anyone atempted this? i have a badass 400 sitting in my garage and a friend just gave me his luv. i make fiberglass scoops and hoods, so i will make a complete front end for theis truck if i decide to do this, it will also get a tonneau cover.
i just need some insight as to what kind of trouble im in for.
any help is appreciated
PostPosted: Fri Feb 13, 2004 8:58 am
Well since its a big block...you got some work ahead of you. Most guys opt to put a Small Block in. Because the size and fit is just perfect basically. There has been a few guys go the big block route, but most like the more simpler version of a small block swap.
Biggest thing is you might have to cut the inner fenders some, steering column shaft will probably have to be relocated, and basically firewalll modifications. You are also gonna have to make engine mounts and mount a new radiator, etc. Those are the basics, and if i didn't scare you off from doing it....Good luck!
PostPosted: Fri Feb 13, 2004 10:45 am
yeah get ready to do alot of custom fabrication.
:D
03Cobra
PostPosted: Mon Feb 16, 2004 7:02 pm
A Buddy of mine back in hi-school put a sb 400 in his 73. He had an old Catalina and a Luv with a dead, stock motor. The other mods he made were mounting the radiator forward of the support. Also he drilled holes in to the fenderwells to access the plugs. He kept the stock axle and he never had a problem. It was stolen from him around 1980. He's in jail now but i know he thinks about that truck.
PostPosted: Mon Feb 16, 2004 9:25 pm
that would be cool. i have a old pontiac bonneville up in the country with a 455 pontiac and auto trans. been sitting for along time, but was driven and ran good when set up. i went up there a while back and the motor would turn over and the oil looked good so i bet it would run. i've thought about putting it into a luv but don't know if i wanna cut the firewall.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
