It is currently Wed Jun 24, 2026 1:59 am
PostPosted: Sun Mar 15, 2020 2:11 pm
Trying to find out if anybody has used a different header once the torsion bars have been removed. Running coil overs with a motor plate and the hookers wont work with the chassis setup.
PostPosted: Sun Mar 15, 2020 4:40 pm
I had custom built on the race truck with the bars removed
PostPosted: Wed Mar 18, 2020 1:46 pm
well the hookers worked well. I will only have to modify the removable tube on the passenger side. My heads are angle plug as well and i see no issues with using 90 degree boots.
PostPosted: Tue Dec 03, 2024 8:50 am
I realize this post is older. I have the same question. I heard that first gen Camaro headers "should" fit with the torsion bars removed but I haven't found anyone that says they have actually done it. Any one out there?
