It is currently Sun May 24, 2026 8:51 pm
 Post subject: 4.3 v6 swap questions
PostPosted: Mon Oct 09, 2023 8:18 pm
Hey y’all, i’m looking to swap a 4.3 v6 and nv3500 5 speed into my 75 luv. Donor truck is a 93 Chevy 1500(has the 4.3 and 5 speed i’ll be using). I’m planning to keep the tbi and just leave it stock for the time being and use the stock harness from the 1500 to run it. I’m planning to use Power By Ace 4.3 swap mounts, and im not sure if they sell nv3500 mounts, if they do im going to buy them.
My question is what driveshaft can use for this? im planning to use a chevy s10 rear end but i’m unsure if i can use the camaro driveshaft like the budget build guide has shown.
I’m also interested to hear what cooling systems y’all have set up for your 4.3 swaps and what clutch pedal setups anyone has used.
Thanks
'75 LUV, Currently waiting for me to put a motor in it
PostPosted: Sun Oct 22, 2023 9:09 pm
You'll need to have a driveshaft custom made. Look for a drive line shop in your area. They'll probably want you to bring the truck to them so they can see which two ends and what length you'll need.
If you can't utilize the stock clutch pedal, Summit sells them. Just have to shop for what will work for you.
