It is currently Fri May 17, 2024 9:46 pm
PostPosted: Sun Mar 15, 2020 2:11 pm
Trying to find out if anybody has used a different header once the torsion bars have been removed. Running coil overs with a motor plate and the hookers wont work with the chassis setup.
PostPosted: Sun Mar 15, 2020 4:40 pm
I had custom built on the race truck with the bars removed
PostPosted: Wed Mar 18, 2020 1:46 pm
well the hookers worked well. I will only have to modify the removable tube on the passenger side. My heads are angle plug as well and i see no issues with using 90 degree boots.
