It is currently Mon May 06, 2024 5:14 pm
PostPosted: Fri Aug 17, 2018 8:33 am
Recently bought a 74 Luv, I am very new to these so I don't know exactly what I have and what I am dealing with. My main focus right now is upgrading the ignition to electronic. Most of the threads I find are dealing with later model Luv's so I am just trying to see what works for what I have.
I have read that dizzy's from some earlier Isuzu's will work.
Am I able to use an earlier Isuzu electronic dizzy with the engine in my 74?
Which dizzy/parts are the most commonly used?
Sorry for a post that has probably been covered a lot, after reading a half a dozen threads I just wasn't finding anything to do with a 74(Mostly 79-80's) and I have seen a bunch of different distributors being used. Along with most of the users that were offering advice have not been on in a few years.
Thank you in advance for any info or advice
PostPosted: Fri Aug 17, 2018 5:39 pm
Not a factory drop in available, I believe. Pertronix might have a conversion kit for your stock one though...
PostPosted: Fri Aug 17, 2018 7:14 pm
That is what I was thinking, thank you.
I saw Pertronix mentioned a lot so I will probably go that way
PostPosted: Fri Aug 17, 2018 7:31 pm
http://www.luvtruck.com/pdf/LUVignitswap.pdf
