It is currently Sun May 24, 2026 9:37 pm
PostPosted: Thu Sep 08, 2016 6:19 pm
I can't for the life of me get the passenger side on. I'm going from underneath and even with clearance dings I can't it past. the cylinder 8 tube gets in the starter area but then I can't wiggle anything else. I would try lifting the entire engine up but I don't have a cherry picker+ with Power by ace mounts the transmission is touching the firewall/transmission tunnel. Next thing I guess i'll try is dropping the oil pan from underneath, I kinda dread doing that... How did you guys get them installed?
1977, Currently in the process of SBC 350/TH350 Swap.
PostPosted: Thu Sep 08, 2016 7:50 pm
Underneath with the starter removed and the engine lifted...
PostPosted: Fri Sep 09, 2016 10:21 am
You could try removing the torsion bar temporarily. I couldn't get mine to come out so I ended up picking up the motor, getting the header in place, and setting the motor down to it.
PostPosted: Fri Sep 09, 2016 3:10 pm
Forgot to mention , I'm running QA1 Coilovers. A Starter isn't on and no torsion bars in the way. Looks like lifiting the engine is the only way to do it now haha. Gotta get the cherry picker back. 4 hour road trip time! I was just in a frustrated state when I made this thread. Should be smooth sailing once I get my picker back. Thanks guys!
PostPosted: Sun Sep 11, 2016 7:23 am
I have one , but before driving 8 hours I would rent one . A place here in town has one with car tires on it that hooke to the bumper for $40 a day
